Date/Time: Mon, 03 Feb 2025 13:55:37 +0000
Sierra on ARM proceros
View Count: 1165
[2019-11-23 12:33:26] |
User513228 - Posts: 41 |
Hi i want buy tables Microsoft Surface Pro X with ARM procesor. Im not tech guy but some apps have problem running corrently on this type of procesors and developers revealing ARM versions of thier apps. How about sierra ?
[2019-11-23 15:12:06] |
We do not think Sierra Chart will be able to run on ARM. We definitely do not recommend this. It is made for X64 processors: https://en.wikipedia.org/wiki/X86-64 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-23 19:58:25] |
ForgivingComputers.com - Posts: 994 |
There is the Surface Pro and the Surface Pro X. The Surface Pro is Intel x64 based. I suggest getting the one with the i7 chip. This will work fine for Sierra Chart. The Surface Pro X is ARM-based. Unless there is some really good reason to go with the ARM processor, you are going to have compatibility issues. Windows Store Apps are the only ones you will be able to run on it. Not Sierra Chart nor a billion other apps that were written for the Intel CPU architecture. |
