Date/Time: Mon, 03 Feb 2025 14:07:21 +0000
Chart scaling goes haywire
View Count: 572
[2019-11-23 10:47:56]
User474409 - Posts: 10
Hi
I had CL contract loaded with 5 mins chart. I converted it to a continuous futures contract. Then I changed the time frame to daily. The chart downloaded but the scaling has changed. I tried doing 'Reset' as well as other options but I cannot seem to recover(See attached before and after). What is the quickest way to recover from it and automatically set the correct resolution
Thank you
imageBefore.PNG / V - Attached On 2019-11-23 10:46:39 UTC - Size: 75.7 KB - 243 views
imageAfter.PNG / V - Attached On 2019-11-23 10:46:47 UTC - Size: 67.64 KB - 259 views
[2019-11-23 10:54:52]
Ackin - Posts: 1865
Try:
Scale Range (Scale Settings)
Chart Scale and Scale Adjusting: Scale Range (Scale Settings)
Date Time Of Last Edit: 2019-11-23 10:55:22
[2019-11-23 14:28:22]
Refer to this section:
Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales.
Date Time Of Last Edit: 2019-11-23 14:28:28
