Date/Time: Mon, 03 Feb 2025 14:08:02 +0000
sc.fileclose() doesn't release memory
View Count: 597
[2019-11-23 08:10:33]
User735389 - Posts: 189
i have a loop creating thousands of files, where i create a new file, write to it, then close it. Memory builds and isn't being released until i close sierrachart.
[2019-11-23 21:07:56]
We think the memory use issue is at the operating system level. It could not be within Sierra Chart. When you make a call to sc.FileClose and a nonzero value is returned, the file was successfully closed.
[2019-11-23 21:26:37]
Definitely confirming there is no problem at all with closing a file from ACSIL and the memory is released. Besides, from the side of Sierra Chart there is virtually no memory even used with file operations. Really no memory at all.
Date Time Of Last Edit: 2019-11-23 23:46:22
[2019-11-24 04:34:23]
thanks i verified this as well. the culprit was suprisingly SCString.AppendFormat(). I created a separate support thread for it.
