Date/Time: Mon, 03 Feb 2025 14:11:16 +0000
[User Discussion] - Price Channels
View Count: 1936
[2019-11-23 07:18:35]
User160486 - Posts: 40
I wasn’t able to find the price channels on your indicators list. The donchian Channel are not the same. I have used price Channels when I used the charting system before yours and found them extremely useful.
Would it be too much trouble to have them added to the indicators?
imageCDC83C42-81EB-4411-A404-DCA2E551A294.png / V - Attached On 2019-11-23 07:17:31 UTC - Size: 1.21 MB - 567 views
[2019-11-23 08:06:03]
Ackin - Posts: 1865
Try this:
Highest High/Lowest Low Over N Bars
- default study from list
[2019-11-23 08:17:31]
Ackin - Posts: 1865
Keltner Channel
Keltner Channel
Moving Average Envelope
Standard Deviation Bands
Hurst Bands
Hurst Bands
Starc Bands
Starc Bands
Standard Error Bands
Bollinger Bands
Bollinger Bands
and if you like a very flexible indicator read this thread:
Interquartile Range Bands
[2019-11-23 09:57:51]
Thank you, Ackin. Very helpful but it is still not the price channels I’m looking for.
[2019-11-23 10:20:51]
Ackin - Posts: 1865
Specify what the price channel is for you. It has more forms/names, depending on who made the indicator.
For me:
Upper Price Channel: The highest high over a user-defined time period.
Lower Price Channel: The lowest low over a user-defined time period.
see post #2
There are of course different mutations and modifications because the channel can be created from any curve with two offset lines.
Sometimes the Price channel is also called the Linear regression channel and vice versa
Look at:
Linear Regression End Channel
or tools:
Chart Drawing Tools: Linear Regression
(but according to your attached picture in the first post you are looking for something similar to Max/Min High/Low per userperiod)
Date Time Of Last Edit: 2019-11-23 10:35:28
[2019-11-23 12:03:03]
The hi and low bar over N looks like a good replicate. Thank you for your recommendation and help.
