Date/Time: Mon, 03 Feb 2025 14:07:42 +0000
Symbol alerts are not working
View Count: 752
[2019-11-22 18:40:21] |
User871249 - Posts: 1 |
Symbol alerts are not working. Any idea what to check. Thanks
[2019-11-22 18:42:10] |
You just need to carefully go over the settings of each Symbol Alert that is not working and make sure they are correct. And make sure Sierra Chart is also connected to the data feed and that there is data available for that particular symbol from the data feed. Instructions: Alerts Manager: Troubleshooting Symbol Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-23 05:05:50
