Date/Time: Mon, 03 Feb 2025 13:49:27 +0000
1 tick price bar doesn't match with the volume
View Count: 964
[2019-11-22 17:05:48]
User921987 - Posts: 238
Is it normal behavior in 1 tick bar chart if the volume is only 1 contract but the price bar height is 3 ticks OR if the volume is 2 contracts but the price bar height is 25 ticks ?
Please see the specifics in the following picture
http://www.sierrachart.com/image.php?Image=1574441872276.png
Data source is CQG
[2019-11-22 17:47:32]
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
[2019-11-22 18:11:39]
I carefully followed the instructions but it didn't give any help for the situation:
http://www.sierrachart.com/image.php?Image=1574446242899.png
[2019-11-22 22:32:51]
Make sure you followed step 7 here:
Tick by Tick Data Configuration: Instructions
Actually we see what the problem is. You scrolled back in time to another contract month and only 1 second data is available. Simplest thing to do now is to update the latest prerelease 2014 because the newer versions use different historical data for CQG users which is tick by tick even for prior contract months.
Date Time Of Last Edit: 2019-11-23 04:16:37
[2019-11-23 08:03:34]
I did the whole TickByTickDataConfiguration procedure again (each step) but it still does not give any help for the situation.
But I think I found the problem. For some reason only the newest contract will fetch with interval 0. Others are 1.
Here is the log entries:
HD Request # 9 | Requesting Intraday data. Start date-time: 2019-07-09 03:00:00. Record interval: 1. Symbol: CLU19 | 2019-11-23 09:55:31.446
HD Request # 15 | Requesting Intraday data. Start date-time: 2019-08-01 03:00:00. Record interval: 1. Symbol: CLV19 | 2019-11-23 09:55:59.128
HD Request # 16 | Requesting Intraday data. Start date-time: 2019-09-03 03:00:00. Record interval: 1. Symbol: CLX19 | 2019-11-23 09:56:15.729
HD Request # 17 | Requesting Intraday data. Start date-time: 2019-10-03 03:00:00. Record interval: 1. Symbol: CLZ19 | 2019-11-23 09:56:31.550
HD Request # 18 | Requesting Intraday data. Start date-time: 2019-11-01 02:00:00. Record interval: 0. Symbol: F.US.CLEF20 | 2019-11-23 09:56:45.804
I hope this helps.
[2019-11-23 14:32:58]
And what did we say in post #4 above?
Date Time Of Last Edit: 2019-11-23 14:33:19
