Date/Time: Mon, 03 Feb 2025 14:00:49 +0000
Delta calculation under one bar
View Count: 1402
[2019-11-22 16:33:54]
User759953 - Posts: 8
How can i get the calculation under one bar?
See attached picture
imageSierra chart2.jpg / V - Attached On 2019-11-22 16:33:06 UTC - Size: 664.37 KB - 502 views
[2019-11-23 05:11:07]
Have a look at this study:
Ask Volume Bid Volume Difference Text
It looks like you are using the Volume by Price study where each profile is covering multiple bars. The Numbers Bars Calculated Values study always displays one cell per bar, and there is no way to modify that behavior.
What we would recommend is setting the chart bars to a time period equivalent to what you are using for the Volume by Price study and then just use the Volume by Price per bar:
Volume By Price Study: Single Bar Volume Profiles with Bid Volume and Ask Volume
Date Time Of Last Edit: 2019-11-23 05:11:49
