Date/Time: Mon, 03 Feb 2025 14:04:22 +0000
TPO Probleme
View Count: 634
[2019-11-22 15:30:00] |
User705024 - Posts: 3 |
Guten Morgen, ich habe mir Packet 5 gekauft von Ihnen und arbeite gerade wieder mit Sierra, mein Datenfeed kommt von AMP. Alles läuft so weit so gut, aber der Footprint und das TPO Profil öffnen sich nicht mal. Irgendwas stimmt mit den beiden study´s nicht ... danke Joseph Pfeifer |
[2019-11-22 17:56:38] |
Translation from Google Translate: Good Morning,
I bought Packet 5 from you and I'm working with Sierra again, my data feed comes from AMP. Everything goes so well so far, but the footprint and the TPO profile do not even open. Something is wrong with the two study's ... You should not have any trouble with either of those studies, although you cannot use them both at the same time within the same chart. Please try to add just one of them to a standard chart without any other studies on it. Instructions: Time Price Opportunity (TPO) Profile Charts Numbers Bars If you are unable to get either of these studies to display properly in this basic configuration, then provide an image of the chart following these instructions: Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-22 17:59:50
