Date/Time: Mon, 03 Feb 2025 13:50:51 +0000
Horizontal Tool Line
View Count: 586
[2019-11-22 13:58:42] |
Dazzer - Posts: 8 |
Hi, when applying a horizontal line to a numbers bars chart, it covers the numbers, is there any way to make appear behind the numbers?
[2019-11-23 04:31:05] |
nicktrader - Posts: 734 |
see pic
Drawings underneath.png / V - Attached On 2019-11-23 04:30:03 UTC - Size: 42.95 KB - 248 views |
[2019-11-23 04:57:00] |
Refer to: Chart Drawing Tools: Controlling Display Order of Chart Drawings Relative to Graphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
