Date/Time: Mon, 03 Feb 2025 13:53:45 +0000
DOM limit order set [Buy clickPrice-1,-2,-3,-n]
View Count: 572
[2019-11-22 08:51:51] |
User234172 - Posts: 44 |
Anyway to do this, with a ladder mouse click. Place a pre-defined set of limit orders at the clicked price on the buy/sell column in the DOM. The closest I can do is set up 3 hotkeys mapped to the available Buy Bid-1,-2,-3. And press them all at the same time |
[2019-11-23 04:20:33] |
Yes we think you could do this by using Attached Orders and the Send Attached Orders feature: Order Types: Send Attached Orders - Position/Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-23 04:21:30
