Date/Time: Sat, 12 Sep 2026 02:37:38 +0000
Number of Trades to show above current bar
View Count: 1112
| [2019-11-22 00:28:13] |
| osaga - Posts: 53 |
Hello I am using a Number of Trades per Bar chart type set to 200. Is it possible to show the current number of trades as a number that updates above the current price bar (and only the current price bar). Basically I want to have an idea when the bar will close. So as it gets very close to 200 I know the bar will close shortly. I can currently see it in region 2 where I have the "Number of Trades" study setup. Want to know if I can get this number above or as close to the current price bar as possible. Thank you in advance |
| [2019-11-22 05:10:12] |
Have a look at this study: Countdown Timer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-22 07:47:58] |
| Ackin - Posts: 1865 |
You can use the default study from Sierrachart: Text Display For Study | Text Display For Study from Chart Text Display For Study |
