Date/Time: Mon, 03 Feb 2025 13:57:15 +0000
ACSIL
View Count: 706
[2019-11-21 22:41:03]
User630795 - Posts: 92
I am trying to write a custom study and I would like to know how to make the study plot new plots at beginning of each day on the chart. for example, your "daily pivot point" study plots new pivots at beginning of each day while preserving previous days' pivot level plots. (instead of just plotting current day's pivot levels ignoring all previous days' level plots.) hope this makes sense. can you show me an example of the code showing how to do it? I am trying to plot levels/zones on daily basis similar to daily pivot points/levels. thank you.
[2019-11-22 00:13:53]
If you only want to have data for the current day and you have set into the Subgraph arrays, values for prior days, then those array elements just need to be cleared.
Maybe having a look at the Current Price Line study will be helpful:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies
