Date/Time: Fri, 19 Apr 2024 12:53:36 +0000
[Programming Help] - Changing Color On the Main Price Chart.
View Count: 853
[2019-11-21 18:47:51] |
User551752 - Posts: 25 |
How do i change the color on the main price chart using ASCIL C++ ? For example, I want to change the color of the candles to red when the trend is going down.
[2019-11-21 23:27:49] |
Ackin - Posts: 1863 |
For example the study: "Color Bar Based on Slope" in the /ACS_Source folder in the folder Sierra Chart is installed -> Studies2.cpp check "SCSFExport scsf_ColorBarBasedOnSlope" To the extent there are any examples, they would be in the /ACS_Source folder that is included with your Sierra Chart install. Refer to the information here for how to search through those files for potential example programs:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies |
[2019-11-25 03:47:40] |
Yes post #2 makes reference to a good example to look at. Let us know if that answers your question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-25 03:47:52
[2019-12-06 23:01:50] |
Yes, I does. Thank you !
