Date/Time: Mon, 03 Feb 2025 13:57:34 +0000
micro emini sp 500
View Count: 1783
[2019-11-21 17:42:23] |
User402468 - Posts: 2 |
hello What is the symbol of the micro e mini sp 500 and on which exchange can I find it (I search on the cme exchange in your web site and do not find it) thanks |
[2019-11-21 19:01:07] |
File >> Find Symbol >> Futures-CME: It starts with MES. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-21 19:57:11] |
I know but I asked you what data feed I need to subscribe to because on your website the symbol MES doesn't appear on the cme or globex exchange so do i need the cme group or just cme data exchange ?
Screenshot_2019-11-21-20-49-40.png / V - Attached On 2019-11-21 19:54:26 UTC - Size: 96.57 KB - 324 views Attachment Deleted. |
[2019-11-21 21:16:15] |
You would just need the CME exchange for that particular symbol. Not the CME Group.
