Date/Time: Mon, 03 Feb 2025 13:49:30 +0000
heikin-Ashi.138 scs file
View Count: 655
[2019-11-21 15:45:40] |
User807128 - Posts: 18 |
Thank you very much for all your help . I used heikin-Ashi.138 scs file and when i use area 1 to draw the chart , two chart appears on the display. how can i view only one chart using this spreadsheet formula ? Thank you. |
[2019-11-21 17:31:04] |
The Heikin Ashi spreadsheet file is not meant to be directly used. It is just there for reference to understand the calculation. You should just use the Heikin Ashi study directly: Heikin-Ashi Be sure to enable the option to display it as the main price graph as the documentation explains. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-21 17:31:16
[2019-11-21 20:04:09] |
Thank you very much for your reply.
