Date/Time: Tue, 15 Sep 2026 15:19:51 +0000
TPO Charts
View Count: 904
| [2019-11-21 15:17:37] |
| User151561 - Posts: 8 |
I've used Sierra for better than 4 years and have navigated thru problems fairly well. As of this morning login, my TPO and candle charts which have been either set on 24 hr or day/evening start times, are no longer giving me an evening chart (TPO). Overall all charts are basically malfunctioning (ie., blank historical areas) after I was directed to download the latest version this a.m.. I have double checked my chart settings for evening and day start times...? Your help would be greatly appreciated...
| [2019-11-21 17:24:49] |
The next thing to check is the time zone: Time Zone Setting If you need more help let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
