Date/Time: Mon, 03 Feb 2025 14:03:16 +0000
Replay Chart not working
View Count: 762
[2019-11-21 09:25:37] |
User161648 - Posts: 3 |
Dear Support, Replay Chart seems not working, Chart -> Replay Chart -> Replay Chart (Control Panel) and the dialog box is not showing up ... Could you please advise on this issue, thank you. |
[2019-11-21 09:58:53] |
User907968 - Posts: 825 |
Did you try the 'Reset Windows' command, found in the 'Window' menu? Window, CB and CW Menus: Reset Windows (Window) |
[2019-11-21 14:01:37] |
Yes that command will resolve this.
