Date/Time: Mon, 03 Feb 2025 13:48:54 +0000
Renko chart - add volume and time
View Count: 881
[2019-11-20 21:49:31] |
User150852 - Posts: 38 |
I would like to place inside\above\below the brick the brick's volume and the time spent in the brick. is it possible?
[2019-11-20 22:19:35] |
Ackin - Posts: 1865 |
Volume Volume 1) Add to the chart default SCH Study Volume 2) Study settings - In the tab "Settings and Inputs" set Chart Region on Value 1 - In the tab "Subgraphs" change Drawstyle to "Value on Low" - Set the width as you need and confirm with "apply" or you can use study Bar delta below bar for Ask-Bid volume Bar Delta Below Bar xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Time (Bar time duration) Bar Time Duration 1) Add to the chart default SCH Study Bar time duration 2) Study settings - In the tab "Settings and Inputs" set Chart Region on Value 1 - In the tab "Subgraphs" change Drawstyle to "Value on High" - Set the width as you need and confirm with "apply" Date Time Of Last Edit: 2019-11-20 22:24:29
[2019-11-21 17:17:10] |
The answer given above is good.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-21 17:17:17
