Date/Time: Mon, 03 Feb 2025 13:47:34 +0000
How to define Point and Figure bars colors?
View Count: 948
[2019-11-20 21:37:55] |
User150852 - Posts: 38 |
Documentation says Point and Figure bars replaces the study, but then, how to define various properties that i could define on the study, e.g. colors, graph draw type...?
[2019-11-21 04:34:21] |
Refer to: Color Settings for Graph Draw Types And: Chart Settings: Graph Draw Type (Chart >> Chart Settings >> Bar Period >> Graph Draw Type menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-21 10:05:08] |
Regarding https://www.sierrachart.com/index.php?page=doc/GraphDrawTypesColorSettings.php... these are good for study. as i define here a chart type (there is no study), it is not clear where the coloring and other properties should take place
