Date/Time: Sun, 24 Nov 2024 23:48:23 +0000
[User Discussion] - Non NET version toolbar buttons
View Count: 1933
[2013-12-23 17:46:12] |
ldrews - Posts: 9 |
I have set up Sierra Chart non Net version on LinuxMint16 using Wine. The toolbar buttons are not readable, but I am not able to find any way to change the toolbar button text font. Please see uploaded image: http://www.sierrachart.com/image.php?l=1387820409117.png Thanks. |
[2013-12-23 17:47:24] |
This is not within the scope of our support. This is marked as a User Discussion. We have seen some discussion of this on the Support Board. You may want to do a search about this problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-23 19:22:40] |
ganz - Posts: 1048 |
ldrews - close SC - try to add into ~/.wine/user.reg [Software\\Wine\\X11 Driver] 1227050429
"ClientSideWithRender"="N" Date Time Of Last Edit: 2013-12-23 19:36:25
[2013-12-23 19:40:25] |
ldrews so set "ClientSideWithRender"="N" also unpack and place the fonts into ~/.wine/drive_c/windows/Fonts/ |
sc.rar - Attached On 2013-12-23 19:40:12 UTC - Size: 304.86 KB - 580 views |
[2013-12-23 23:14:38] |
ldrews - Posts: 9 |
ganz Thanks, that worked like a charm. I have one other problem you could perhaps help me with. The main menu line flickers with some type of redraw on a regular basis, approx 1/2 sec. Do you have any insight into that? Regards, Larry Drews |
[2013-12-24 00:00:19] |
ldrews >> main menu line flickers there is no solution on wine1.4 |
