Date/Time: Mon, 03 Feb 2025 14:10:07 +0000
Small Icons on 4K laptop
View Count: 692
[2019-11-20 01:23:07] |
User8600 - Posts: 10 |
Why the menu icons are too small on Sierra chart on my 4K laptop, they look OK on my normal HD desktop. Please see attached image. |
[2019-11-20 04:08:45] |
You need to increase the Control Bar button Text size and use text instead of graphics for the buttons that use graphics: Control Bar: Control Bar Buttons Size and Text Size Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
