Date/Time: Wed, 05 Nov 2025 05:51:59 +0000
Global cursor w/ drawing tools
View Count: 1456
| [2013-12-23 17:42:01] |
| SgtJ - Posts: 154 |
Recently upgraded from 997 to 1061. I always have global cursor enabled and the chart values cross hair is always on when using other tools. W/ 997 I could select a draw tool, go to the active chart and if the global cursor didn't display on a secondary chart I was visually referencing I just had to mouse over that chart briefly and the cursor would appear (I'd could then align the drawing ref'ing the 2nd chart). Unfortunately this seems to have stopped working post upgrade. I tried adjusting various chart value options w/ the same result. Is the desired effect still possible? |
| [2013-12-25 04:40:47] |
We will be looking into this. This is the result of solving a problem for another user. So we probably will just revert the change. Unless you can live with it.
| [2013-12-27 07:58:55] |
This will be resolved in the next release coming out later today.
