Date/Time: Mon, 03 Feb 2025 13:03:53 +0000
Crude rollover
View Count: 584
[2019-11-19 15:36:48] |
User312588 - Posts: 5 |
Hello I ham having trouble with CL charts and quotes. I have used Sierra Charts for a couple years now and I have never had a problem like this where I can't find a solution. I have the Team Viewer installed and could probably use some remote assistance on this one. Problem: When I try and roll over the Crude contract it never pulls up the correct month, I also try and manually put in CLF0-NYMEX and that doesn't work either. Please advise. Thanks! Date Time Of Last Edit: 2019-11-19 15:38:10
[2019-11-19 16:35:10] |
You need to update to the current version. Instructions: Software Download: Fast Update We also recommend migrating over to this service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-19 17:39:15] |
Ok that was it. Thaaaaaanks!
