Date/Time: Mon, 03 Feb 2025 14:04:39 +0000
USOil price slightly off
View Count: 540
[2019-11-19 15:06:20] |
samuelson - Posts: 9 |
Since I purchased Service Package 5 I noticed USOil WTI (CFD) is off by around -$0.08. I am comparing it to other charts like on investing.com for example. Not sure if this started since I upgraded or prior to that, as I haven't used Sierra charts for a few days, but it was OK earlier. I tried "Delete All Data And Download" but it's the same. Date Time Of Last Edit: 2019-11-19 15:07:13
[2019-11-20 04:37:39] |
That is a CFD symbol. It comes from FXCM. We cannot help with this. We recommend using the futures prices instead. Update Sierra Chart to the latest prerelease 2013: Software Download: Fast Update And then open a chart for CLF20. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-20 04:38:20
