Date/Time: Mon, 03 Feb 2025 14:06:01 +0000
Rebreak of level entry
View Count: 592
[2019-11-19 13:00:20]
User875891 - Posts: 63
I had asked about this in the past and SC had mentioned they were working on it
Essentially what I was asking is if a support (or resistance) level has been breached is there a study (or a trade window option) to enter a trade when the support level is rebroken?
ie if sup is broke then price moves above tht support level I wud be able to automatically enter Long
[2019-11-21 00:14:34]
It is not completely clear specifically what you need. It sounds like you might need to create your own automated trading study:
Automated Trading From an Advanced Custom Study
However, have a look at the different order types here to see if Sierra Chart has what you need:
Order Types
But it does sound like one of the Triggered orders would probably do what you want.
Date Time Of Last Edit: 2019-11-21 00:15:42
[2019-11-22 14:43:33]
looks like "trigger Limit" is what i was lookig for
thnx
