Date/Time: Mon, 03 Feb 2025 12:54:52 +0000
standalone installer for version 2011
View Count: 735
[2019-11-18 21:50:09]
User123202 - Posts: 4
hi i'm a linux user. i'm trying to update SC to version 2011. but i wasn't successful using SierraChartFileDownloader.exe, or the portable version. is it possible that you can send me a link to a standalone installer for version 2011? i was able to install the previous version 1310SierraChartSetupNoCLRPrerelease.exe only but i need to update in order to work with my datafeed. thanks
[2019-11-18 22:40:33]
You need to use the zip installer:
Software Download: Sierra Chart Zip Installer
[2019-11-18 23:11:53]
i actually just tried that, but still no luck. are there anymore options? thanks
[2019-11-18 23:47:24]
How could you have difficulty with a Zip installer? It does not get any more straightforward than that.
[2019-11-19 03:17:58]
well, after i unzipped to a folder, then i clicked on sierrachart.exe or sierrachart64.exe for installation. sierrchart.exe give me an error(couldn't remember the error) when double clicked on it and abort the installation. sierrachart64.exe doesn't do anything.
[2019-11-19 03:53:12]
Since you are using Linux this is not anything we can help with. We do not know what the problem is. But certainly it is not related to the installer.
[2019-11-19 04:22:48]
anyway, thanks for your help. hopefully your guys have a standalone installer uploaded soon. at the meantime, i might have to switch back to windows.
[2019-11-19 14:46:56]
UnixManiac - Posts: 46
The easiest way to do the update on linux is by opening the older version of SC, go to "Help" -> "Download Current Version" and follow instructions. This will update you to latest version (2011) and re-open SC.
If you still have issues I guess it maybe related to your Linux/WINE installation, which hopefully I can help if you provide more info like what distro you are running, how you installed Sierra Chart in the first place and how you are launching it.
