Date/Time: Mon, 03 Feb 2025 13:06:55 +0000
Help connecting to Gain Capital
View Count: 646
[2019-11-18 19:36:47] |
User468495 - Posts: 1 |
> Hello, the platform not work. : Waiting to reconnect > trade service settings: Gain capital /OEC > I am trying a demo, please help |
[2019-11-18 23:24:48] |
The preferred solution is to use our new delayed trade simulator. We are setting you up with an account. We are working on this now for you. Here are the instructions: Simulated Futures Trading Service You can use this simulator as long as you want and it is reliable. Also make sure you update to the prerelease version which is 2012: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-19 00:30:23
[2019-11-20 01:35:42] |
Your Sierra Chart account has been assigned a simulated trading account and you can begin to use the Trading Evaluator-Delayed service: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
