Date/Time: Mon, 03 Feb 2025 13:03:53 +0000
No Real Time Data
View Count: 645
[2019-11-18 17:42:13]
buggsuperstar - Posts: 33
Hello, I setup the denali feed but I am not seeing the M in the chart or receiving real time data. Can you please look? I'm looking at an ES chart.
[2019-11-18 17:46:15]
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges)
We also want you to update to the current version following the instructions here:
You will then begin to at least receive the delayed data.
[2019-11-18 18:00:05]
I use NinjaTrader with Dorman. However right now I just want the ability to SIM trade with Sierra.
[2019-11-18 18:06:36]
Later I would like to hook it up to a live account. Is there a clearing house/broker that you recommend that works best with Sierra?
[2019-11-18 18:13:33]
The more I'm reading I'm seeing that there is a delayed stream no in the package 5. Do you think this is a better option?
[2019-11-18 18:17:38]
Would you be ok with delayed data? If so we can cancel and refund the real-time data feed. You can continue to be with Dorman and use Sierra Chart for trading. You can use our TT based order routing with Dorman.
Date Time Of Last Edit: 2019-11-18 18:18:27
[2019-11-18 18:21:18]
Sure! Let's do the delayed streaming data for now please and then when I'm ready I will set up Dorman through the TT routing. Thanks so much.
[2019-11-18 18:23:54]
Ok you just need to update Sierra Chart by selecting Help >> Download Current Version. If you need further help let us know. An update is all that is needed.
Let us know once that is working and if it is ok then we will refund the other data feed for you.
[2019-11-18 18:28:15]
Yes, It has been updated and it running now although I am still only seeing historical data.
[2019-11-18 18:38:33]
Would it be ok that we call? We can call in about 15-20 minutes.
[2019-11-18 18:40:17]
Of course. ***.
Date Time Of Last Edit: 2019-11-18 20:38:22
[2019-11-18 19:26:47]
Hi and thanks for the call. It's been 10 minutes and still the only thing that is streaming is the DOM on the right side of my charts. The charts itself only update when historical data is downloaded.
[2019-11-18 20:39:05]
In regards to using Sierra Chart with Dorman for trading this is the recommended service:
Sierra Chart / Trading Technologies Futures Order Routing Service
Or you could use CQG:
CQG Trading Platform Service
[2019-11-18 20:54:23]
In regards to post #12, this is not an issue any longer.
