Date/Time: Fri, 21 Feb 2025 18:15:39 +0000
Overlaying timeframes
View Count: 1878
[2019-11-18 16:20:56] |
User740709 - Posts: 153 |
Hello, I am trying without success. Could you please tell me which study will overlay 5 1-min bars by 1 5-min bar? I.e. how to lay higher time-frame bars over lower time-frame bars? Thanks a lot. Regards. |
[2019-11-18 22:41:14] |
It is the same study in either direction - Study/Price Overlay. You will need to review the Inputs for the study and work out which options will work best for what you are trying to achieve. Refer to the information here: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-19 10:09:17] |
I have succeeded in creating 30min rectangles over six 5min bars. However, I would like them to look more like the 30min candles not full rectangles, for example as rectangles with ligher color from open/close to high (for an up bar) and from open/close to low (for a down bar) and also it would be better if the colors could be set to transparent. But I am unable to change any setting on the Subgraph tab, every time I try the values return to default. Is it doable? Thanks a lot. All the best. |
[2021-01-21 15:48:28] |
User690267 - Posts: 13 |
I am wanting the same as User740709. Anyone out there know how to do it? is it possible? I have attached a screen shot if it helps. 15min candles made up of 1min candles inside. Would be great to see this made possible as i cant see an option in the Study/Price Overlay. Thanks |
Attachment Deleted. ![]() |
