Date/Time: Mon, 03 Feb 2025 13:09:55 +0000
data
View Count: 767
[2019-11-18 14:57:20] |
User718663 - Posts: 39 |
hi, the new data i purchased thru SC is not working. price is not moving on the chart. |
[2019-11-18 15:20:37] |
For what symbol?
[2019-11-18 16:18:43] |
If it is a CME Group symbol. You should now be receiving streaming data for the symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-18 16:18:54
[2019-11-19 02:19:23] |
hi, it's for every symbol. for ex, like roku, aapl, tsla. |
[2019-11-19 03:35:50] |
These are US equities symbols. You need to activate the US Equities exchange here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-19 15:31:00
