Date/Time: Mon, 03 Feb 2025 12:51:19 +0000
How to Colour time Based Candlisticks with Volume
View Count: 1287
[2019-11-18 11:31:05]
User270832 - Posts: 8
Hello
I want to colour my Time-based Candlesticks with Colours with different Volumes intraday.
SO the Candle it self is not the subject of Change only the Colour shows different Volume "Types"
I looked into the Graph Draw Type but nothing really matched:
Cheers Joshua
[2019-11-19 03:47:02]
You would want to use the Color Bar Based on Alert Condition study. You would need one study for each color/logic that you are using. Refer to the following:
