Date/Time: Mon, 03 Feb 2025 17:19:04 +0000
PAYPAL
View Count: 992
[2019-11-18 09:42:09] |
User686528 - Posts: 13 |
Good Day, is it n longer possible to pay via Paypal? I have been paying for my Sierra Chart usage via Paypal. Ive tried to renew it and for some reason I struggled to do so via PayPal. I have been trying for some time now. can you please assist me. thank you, Akinsano |
[2019-11-18 14:37:42] |
PayPal has been removed. There are other payment options for you to use. Let us know if you have a problem with those and explain why. We have extended your account for now by 7 days. For information about PayPal, refer to: Why PayPal has been Removed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-18 14:54:23] |
Sir/Maan sad to see them go. I will look at suitable alternatives. thank you for understanding... on a completely unrelated and very opportunistic note, I have attached a screenshot of your beautiful Footprint Chart. can you please please send it to me, I dont know if you can see my chartbooks on your side but mine is weak. I'd really appreciate your help, Ive looked everywhere for one and tried to make it for myself with little to no success. regards, Akinsano |
Attachment Deleted. |
[2019-11-18 16:17:54] |
John - SC Support - Posts: 37668 |
We have attached an example Chartbook that contains the Numbers Bars study with coloring similar to the image you showed. Following these instructions to use the Chartbook: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support After you open the chartbook, you will need to select Edit >> Translate Symbols to Current Service. This will change the symbol that we used when we created the Chartbook to the symbol for your trading service. Refer to the following for more information: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-18 20:53:17
NumbersBarsExampleChartbook.cht - Attached On 2019-11-18 16:17:50 UTC - Size: 30.72 KB - 410 views |
[2019-11-30 11:25:29] |
I was able to build on this. satisfied now, thank you!
[2019-12-01 01:26:29] |
PayPal is now available again: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
