Date/Time: Mon, 03 Feb 2025 13:09:47 +0000
SC running really slow since upgrade
View Count: 567
[2019-11-18 09:40:33]
NigelDams - Posts: 9
Hi there - I received a message this morning about an upgrade to the newest version, so I did, and now I wish I hadn't. Every operation is taking way too long, like 2 seconds between mouse-click and response. The machine isn't thrashing, as you can see by the attached screenshot.
I'm sure this is caused by the upgrade though, as it's been fine till this morning.
Any insight much appreciated
imageCapture.PNG / V - Attached On 2019-11-18 09:40:07 UTC - Size: 54.69 KB - 255 views
[2019-11-18 12:00:33]
Refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
If you are using the OpenGL option, then disable that:
https://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#UseOpenGLFforChartGraphics
