Date/Time: Sun, 24 Nov 2024 23:33:45 +0000
[User Discussion] - I am having problems with the Colour bars based on above/below study
View Count: 1388
[2013-12-23 13:17:36] |
RQ - Posts: 50 |
On some charts the study works correctly (bars change colour when they are supposed to). But I am having problems on some charts (the bars remain all the same colour) I cannot figure out why. Colour bars based on above/below study. I am using the Rahul Mohindar Oscillator Input data: Last Study reference: ID1.SG2 (which is correct). Mode: colour above/below Output input data values instead of 1.0 – NO Study reference displacement: 0 The above settings work absolutely correctly on some charts. But when I try setting up a different chart the exact same settings doesn't work. The bars all remain the same colour. I cannot figure out what the problem is. |
[2013-12-23 13:34:59] |
RQ - Posts: 50 |
I have just discovered the problem is just with charts when the JPY is involved. Any chart with JPY in the pair the bars remain the same colour. Have you any ideas what the problem is?
[2013-12-23 18:05:18] |
RQ - Posts: 50 |
Guys can I have an answer to my question please. I have tried everything and still haven't found the root of the problem never mind the solution.
Date Time Of Last Edit: 2013-12-23 18:07:17
[2013-12-23 20:11:18] |
Sawtooth - Posts: 4120 |
Try this: -set the Based On to the Rahul Mohindar Oscillator study. -set the Input Data to ST3 |
[2013-12-23 21:23:51] |
RQ - Posts: 50 |
Thanks Tom, were would be be without you.
