Date/Time: Fri, 25 Sep 2026 15:40:13 +0000
52 week highs VS 52 week lows
View Count: 1523
| [2019-11-18 04:25:45] |
| JEM.TRADES - Posts: 16 |
Hi support, Is there a way I can add an indicator to my charts that will show me the underlying percentage of stocks making 52 week highs VS the percentage of stocks making 52 week lows on the S&P 500? Furthermore, do you also offer an indicator of the percentage of stocks above their 200 Day SMA VS the percentage of stocks below their 200 Day SMA? Thank you in advance. |
| [2019-11-18 23:33:44] |
None of this is easily supported. But you certainly can develop your own scans: Study/Chart Alerts And Scanning But this is quite involved and not simple what you want to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-18 23:34:06
| [2021-05-26 07:48:15] |
| User372414 - Posts: 25 |
52 week high and lows statistics are provided by Barchart: https://www.barchart.com/stocks/highs-lows/summary But I don't see this in Sierra Market Stats. Or is the name different? It would be great to have monthly, quarterly and 52 week highs and lows statistics. Thanks |
| [2021-05-26 14:05:30] |
| John - SC Support - Posts: 48011 |
As stated previously, this is not available.
