Date/Time: Mon, 03 Feb 2025 10:43:34 +0000
Chart Value/Crosshair
View Count: 785
[2019-11-17 00:42:45] |
DblArrow - Posts: 10 |
I am trying to find a way to change color of the Chart Value/Crosshair tool. Did a documentation search and looked through all the global and tool config settings. Did I miss something? Thanks.
[2019-11-17 01:36:59] |
This is explained here: Chart Drawing Tools: Chart Values Tool Configuration (Chart Values Tool Configuration) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
