Date/Time: Mon, 03 Feb 2025 11:03:13 +0000
[Programming Help] - Why does Sierra Chart always start backtests too early?
View Count: 643
[2019-11-16 23:53:08]
j4ytr4der_ - Posts: 944
In evaluating some potential systems, I'm doing a lot of backtesting. I like to use ATBB as a quick first-pass since it's likely to be the most favorable in terms of results (if the results stink there, they aren't gonna get any better with more detail).
But when I run a BBBT, the first trades fire before there is even enough data to generate things like moving averages, etc.
Why is this? And is there a way to get the backtest to only start after all the required indicators are actually plotting data?
Date Time Of Last Edit: 2019-11-16 23:54:03
[2019-11-17 03:45:02]
This is something that you need to control within the trading system itself. There is no way this can externally be known.
Date Time Of Last Edit: 2019-11-17 03:45:09
[2019-11-17 04:02:26]
I'm not sure you've understood me, or I'm not understanding you.
My system already has logic which tests for things like price above or below a certain moving average. But trades are firing on a backtest, before the moving average is even plotted on the chart, so what value is the system using to determine that it should have signaled a trade? My expectation would be that no trade would be possible, if data that is required for the signal to fire, is not available yet.
