Date/Time: Mon, 03 Feb 2025 11:08:15 +0000
keep window in background
View Count: 619
[2019-11-16 18:42:11] |
AKR - Posts: 523 |
probably stupid question, I did search the docu but did not found. how can I keep a detached window behind an other detached window? So far I just click on the window to be in front but any time I do change CB the other one is on top again. Now I know I can set the one supposed to be in front to "always on top", but then i can not choose the one in the background anymore as it will always stay there. |
[2019-11-17 04:05:08] |
It may help to control the order of the chart windows through Window >>Windows and Chartbooks.
[2019-11-17 08:07:27] |
AKR - Posts: 523 |
yes did !!
