Date/Time: Mon, 03 Feb 2025 11:07:11 +0000
Request for new arithmetic study- Study subgraph positive/negative value
View Count: 627
[2019-11-16 11:46:50] |
User499195 - Posts: 4 |
I have a rate of change study of which i am only interested in the positive/negative value that I want to overlay to other chart. Is it possible for sierra chart to add this study in the next release?
[2019-11-16 12:24:07] |
User907968 - Posts: 825 |
What does this "i am only interested in the positive/negative value" mean? Do you want to know the magnitude of the value only and ignore the sign? Study Subgraph Absolute Value Do you want to ignore zero value and overlay only positive/negative ignoring zeros? Study/Price Overlay Study: Study Inputs & set 'Draw Zeros' to no |
[2019-11-17 04:26:38] |
We recommend that you create your own study just based on the existing ones. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
