Date/Time: Mon, 03 Feb 2025 10:53:30 +0000
Input Values on Region Data Line
View Count: 823
[2019-11-16 02:58:35]
HAB-User115006 - Posts: 38
How do I display the Input parameters of a study on the Region data line?
I have checked 'Display Input Values' and I can see input values on the Values window but not on the Region Line
The documentation states:
Subgraphs Tab >> Display Input Values
When this option is enabled, then study Input values will be displayed in the Chart Values Windows and in the Region Data Line. Otherwise, they will not be displayed.
[2019-11-17 04:31:24]
There is a global setting you need to disable and this is explained in the updated documentation here:
Chart Studies: Subgraphs Tab >> Display Input Values
