Date/Time: Sat, 20 Apr 2024 14:18:11 +0000
Spreads for Gasoil and Brent
View Count: 712
[2019-11-15 15:39:19] |
User653688 - Posts: 10 |
Hi Team is it necessary to activate any data feed for accessing Future spreads of Gasoil and Brent? I have currently activated Service package 5. Will i get spreads data with the subscription of only Service package 5? I am unable to access them till now. |
[2019-11-17 03:48:31] |
The practical answer is no. You do need to subscribe to the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed And the ICE Europe exchange (Update: this not needed). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-17 12:48:19
[2019-11-17 20:50:27] |
See update above.
[2019-11-18 06:47:33] |
Just to confirm, in order to get Future spreads data for 100 symbols i need to subscribe for 35$ per month and this is the only one i need to subscribe for?
[2019-11-18 16:47:17] |
You just need the $25 option for 20 symbols a month. And the symbol limit does not apply because it sounds like you just want historical data so you can get as much historical data as you want. There are no limits with this. Yes that is all you have to activate is just one of the real-time connections. And then follow the instructions here: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-18 16:48:09
[2019-11-21 13:14:01] |
I am struggling to understand how to make the payment of 25$ to specifically activate the data feed. Could you please help me out?
[2019-11-21 17:22:37] |
You make the payment here: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Please let us know when that is done. Or if you have any trouble. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-11 18:59:17] |
Hi Team, I have added 25$ to the account as per the suggestion above... Could you please activate the data feed asap....Thank you! |
[2019-12-11 19:58:35] |
Can you please add your telephone number here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Let us know when done. We need this to meet exchange requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-11 20:05:03] |
Hi, I have update the phone number... Thank you! |
[2019-12-11 23:43:53] |
We have activated the Sierra Chart Exchange Data Feed on your account. Follow the instructions here to access spreads: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-20 10:31:35] |
Hi, Is it possible to access continuous charts for "Spreads" (Gasoil and Brent crude) in Sierra? |
[2019-12-22 05:50:53] |
Not sure what the rollover rules would be in this particular case. But if we know we should be able to make this work.
