Date/Time: Mon, 03 Feb 2025 11:00:38 +0000
JUST TO CONFIRM - Question on TT Data Feed
View Count: 837
[2019-11-15 15:05:03] |
User76183 - Posts: 69 |
Hello can you confirm that Sierra Charts will allow to connect with TT-datafeed as stated here: https://www.sierrachart.com/index.php?l=doc/TradingTechnologies.php Because TT representative in Hong Kong worry about whether SC allow TT FIX connection: " I took a look and found one of the sessions said that "So as a matter of policy Sierra Chart no longer will provide any technical help or recommendation for using TT FIX market data". I think it would be great if you can confirm with SC whether they allow TT FIX market data feeding to SC as I worried they don't allow market data from TT FIX. " Just to confirm which connection SC allow- TT FIX or TT FIX 7X ? Please put in consideration that it is NOT only my personal questions.TT staff need to make sure, otherwise they cannot initiate official connection procedures. Thank you for your understanding! |
[2019-11-15 15:30:55] |
You can use TT market data, it is expensive though, but we will not provide technical help for it. And only TT FIX is supported. Not TT FIX 7X. For what exchanges do you need market data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 15:31:31
[2019-11-15 15:37:28] |
CME and probably Eurex and HKEX
[2019-11-15 17:04:26] |
In this case, you really are much better off just obtaining these exchanges from the Sierra Chart Exchange Data Feed. We want to provide good reliable services and it is going to be much better to obtain this data from us. And also you will get historical data. Otherwise, there is no historical data when using TT. So that is a major thing you should be aware of.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 17:04:52
