Date/Time: Mon, 03 Feb 2025 11:09:46 +0000
Study that shows the last value of an other study as text in a chart
View Count: 1182
[2019-11-15 14:53:29] |
AKR - Posts: 523 |
Is a there a study like that?
[2019-11-15 16:45:07] |
Ackin - Posts: 1865 |
This? Text Display For Study | Text Display For Study from Chart Text Display For Study |
[2019-11-15 17:17:20] |
There are a number of options available. The one that sounds like it may fit what you are looking for best is the following: Text Display For Study You will find the list of all Sierra Chart studies here: Technical Studies Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-16 18:31:40] |
AKR - Posts: 523 |
Would it evt be possible to change the study, so you can also use a study from an other chart?
[2019-11-16 19:49:06] |
AKR) Default list SCH studies There is for this "Text Display For Study from Chart" |
[2019-11-17 04:00:06] |
Did you read the documentation for the study?
[2019-11-17 08:12:28] |
AKR - Posts: 523 |
sorry. yes I did. but did not realize there are 2 studies. apologies..
Date Time Of Last Edit: 2019-11-17 09:15:47
[2019-11-17 09:23:10] |
If you would like some improvements, in our forum are modifiacations of the default study. 112) Text Display For Study - improved 113) Text Display For Study (Percent from) 114) Text Display For Study (Slope) 115) Text Display For Study from chart - improved 116) Text Display For Study levels contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:47:14
