Date/Time: Mon, 03 Feb 2025 11:10:40 +0000
Intraday data download failed
View Count: 568
[2019-11-15 13:40:33]
User113238 - Posts: 16
I've used sierra chart since March 2018 solely for the intraday data and it has worked fine until yesterday. When I chose "Open Intraday Chart", the return message is "Download Failed". It is not a problem on my side because the data download still worked for daily, weekly and monthly data. Please check on this issue immediately because this is the only data I need from Sierra Chart. Thanks.
[2019-11-15 13:56:44]
You need to update Sierra Chart to the current version. Instructions:
After the update, to download the missing data, follow these instructions:
Date Time Of Last Edit: 2019-11-15 14:24:34
[2019-11-15 14:28:18]
It works. Thanks.
