Date/Time: Sat, 13 Jun 2026 07:54:18 +0000
[User Discussion] - Ask volume Bid volume difference text
View Count: 2187
[2019-11-15 06:51:59]
DevTrader79 - Posts: 46
I want to display only number such as (234 instead of -234.00 without decimals and sign[-] negative and for positive 97 instead of 97.00) . Went to function studies8.cpp->scsf_AskVolumeBidVolumeDifferenceText(SCStudyInterfaceRef sc).
(1) do I have to set sc.DrawZeros = 0; or false; to turn off decimal zeros and display only number ?
(2) Couldn't figure out how to turn off the sign, especially (-) negative sign.
Any help is highly appreciated.
[2019-11-15 08:32:38]
User907968 - Posts: 872
1) To drop trailing zeros from study subgraph output display:
In ACSIL use variable 'sc.ValueFormat', refer -
- ACSIL Interface Members - Variables and Arrays: sc.ValueFormat
or
From study settings window, refer -
- Chart Studies: Settings and Inputs Tab >> Value Format
2) To remove (-) negative sign you could change the study code so that all the values stored in the subgraph array are positive:
For example (using scsf_AskVolumeBidVolumeDifferenceText)
replace
Subgraph_Difference[sc.Index] = sc.AskVolume[sc.Index] - sc.BidVolume[sc.Index];
with
if (sc.AskVolume[sc.Index] > sc.BidVolume[sc.index])
  else
    Subgraph_Difference[sc.Index] = sc.BidVolume[sc.Index] - sc.AskVolume[sc.Index];
[2019-11-15 19:12:11]
Thanks for getting back to me soon. Sounds good
Possibly I will inject code like this.
It is a great help highly appreciated.
if (sc.SetDefaults)
// initialization existing code
sc.ValueFormat = 0; // my addition no decimal
else
// then the rest as it is
if (Input_DisplayAboveOrBelow.GetIndex() == 0)
//existing code
