Date/Time: Mon, 03 Feb 2025 10:59:24 +0000
Old code from 32 bit to 64 bit platform
View Count: 972
[2019-11-15 01:59:58] |
User837393 - Posts: 132 |
Hello, I'm currently trying to run a code that has been built under 32 bit ASCIL structure, but when I compile I get a bunch of errors. For example how would that line of code be represented into the new structure : float& targetRange = sc.PersistVars->f1 I'm sorry if the question sounds noob, I'm no programer, but would defenetly like to learn. Thank you. Date Time Of Last Edit: 2019-11-15 02:00:38
[2019-11-15 17:28:53] |
Ackin - Posts: 1865 |
ACSIL Interface Members - Variables and Arrays: sc.PersistVars try this: float& targetRange = sc.GetPersistentFloat(1); |
[2019-11-15 18:10:55] |
Yes you need to use the new GetPersistent variable functions: sc.GetPersistentInt() And the code example given in the prior post is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 18:11:07
