Date/Time: Thu, 25 Apr 2024 00:08:54 +0000
clear Current Ask/Bid Volume on new position
View Count: 605
[2019-11-14 15:39:23] |
User433487 - Posts: 7 |
hello, could you please look into -Clear Current Ask/Bid volume on a new position- it does not seem to consistently work, sometimes it works on replay and it most definitely not work on live or sim. And, could it be possible to have the same feature added to clear Current Ask/Bid Volume after clear position as well? I currently run 1997, however, I installed 2008 right before righting this support request and still could not get it to work. thank you, Hishaam Date Time Of Last Edit: 2019-11-14 18:12:33
[2019-11-15 05:34:11] |
We cannot spend any time looking into this. We can only refer you to the documentation for this setting here: Global Trade Settings Windows: Clear Current Bid/Ask Volume on New Position (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Be sure to read it thoroughly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 05:34:25
