Date/Time: Mon, 03 Feb 2025 11:01:31 +0000
How to log in an account?
View Count: 627
[2019-11-14 14:42:50] |
User728833 - Posts: 4 |
Hello To remain eligible for the CME connection discount, I need to log in to my DORMAN account on the platform, right ?! since that is my only account for trading futures ... I don't know how to proceed ... Could you help me? Thank you in advance for your assistance. |
[2019-11-14 15:20:18] |
What is the name of this platform? The verification has to be a technical method of verification. This can only be done if your account through Dorman is on CTS, Rithmic, CQG or TT.
[2019-11-16 14:09:36] |
I don`t think i was clear... to keep paying the non-professional fee from the "data feed"from CME, i understood that i had to connect an account into the SIERRA CHART and the account i could use is the one i have at DORMAN... But if you say i don`t need to connect any thing else on my Sierra Chart plataform to keep paying the same fee i already did this month... than i guees we are fine. |
[2019-11-16 15:46:58] |
Since we do not have a specific answer on our question, at this point we can only conclude, that you are not using a compatible system. And you cannot continue to use the nonprofessional CME fees. So then you will need to pay the higher priced professional fees. If you have Dorman set up your trading account on Trading Technologies that will solve the problem. This is supported: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-16 15:49:02
