Date/Time: Mon, 03 Feb 2025 10:53:32 +0000
Market Depth Data not recording
View Count: 1164
[2019-11-14 11:29:57]
Giamsterdam - Posts: 33
Since a few updates I am having issues recording market depth data - I have enabled the option in the global symbol settings but it's not recording anything? what am i doing wrong?
Cheers,
G.
imageSierraChart_64_BJ9JhWhR99.png / V - Attached On 2019-11-14 11:29:33 UTC - Size: 16.5 KB - 244 views
[2019-11-17 04:53:59]
Is the option at the top of the Symbol Settings window for Use Custom Symbol Settings Values enabled? This has to be enabled for the changes that you make to the symbols to take effect. Refer to the following:
Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings)
Also refer to:
Market Depth Historical Graph: Market Depth Historical Graph Not Displaying
Date Time Of Last Edit: 2019-11-17 04:55:00
