Date/Time: Mon, 03 Feb 2025 10:44:50 +0000
What's wrong with my SC?
View Count: 680
[2019-11-14 02:28:06] |
User897008 - Posts: 48 |
Attached picture Pic1 is original chart picture, after i deleted the intraday data and re-download it, SC show me the Pic2. What wrong with my SC? |
NQZ9 [CV] Flex Renko 25-17-0 #1 2019-11-13 21_17_56.307_P.png / V - Attached On 2019-11-14 02:26:40 UTC - Size: 32.09 KB - 258 views NQZ9 [CV] Flex Renko 25-17-0 #1 2019-11-13 21_20_00.085_P.png / V - Attached On 2019-11-14 02:26:50 UTC - Size: 30.87 KB - 278 views |
[2019-11-14 12:04:42] |
You are using the Transact trading service. Therefore, refer to this information here in regards to this: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SolvingLaggingDataFeed_StoppingDataFeed_MissingDataIssues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
